two assemblies on one distinct base.
leggera
Hello.
I'm building an easy component, but I can't get a certain situation with the component list.
in a few words I have a main set and one at the lower level.
If I only want the parts I go in the main together and hide the lower axieme.
But if in the same table I want to represent the main and lower axieme?
the program manages the component list for view so each view has its own list of components.
top to left the main axieme composed of 5 parts
lower to right the upper plate axieme constituted by a plate and 4 prisoners.
I would like these components of the upper plate axieme to take as ball numbers 4 and 5 as distinct from the general axieme.
In my opinion, if I understood correctly... I would do:
1)create a rapp. of view so as to see one or the later
2) in the distinct assembly components, in the separate component structure column selects "hidden" instead of normal, in this way the distinct does not see the assem "top.iam" but only its parts
I've tried, but it doesn't work.
I think that in the end it is faster to create the distinct from the main axieme and then manually refresh the two balls of the asses below.
It seems strange that there is no such function, but there is no direction.
