unchangeable relationships! ! !
  • Thread starter Thread starter Robocar78
Robocar78
Hello everyone,
Working in wf4 on a part created by others I have 2 strange problems:
1) It is impossible to change the reports or change it can be done as a senmpre but at the exit from the "relations" window in the status bar the following message appears: "modified relationships have been restored." ... and it is true that what I have added disappears and what I have deleted comes back. the same thing happens by going to change from proprogram reports or other parts of program.
2) the modification of the dimansional quotas (...the ones free from relationships) of planes, holes...etc.. is not taken from the command "edit..." : once changed a value and regenerated back the same as before. in this case I solve using "edit definition". This problem is certainly less serious but I think it is related to the first.
I'm working on a big team but only this part shaped in another factory by these problems.
Did someone do the same? How did you solve this?
Hello, thank you.
Surely you have conditional input instructions in pro-program, so that change you want to do is guided by a range of values not allowed, and pro-program rightly forbids you.
Of course, there are some conditioners in the program, but it shouldn't stop me from adding new rhymes, should it?
