undulating spring
  • Thread starter Thread starter Hole
This method is even cooler!
eventually reproduces what is actually done to make the corrugated washer.
I'm sure you'll like it.
thanks for the design, sin that there is not the technique of construction of the corrugated profile on the base cylinder surface! I'll study a little on it!
try to give us an eye I did it in turbocad (the same technique I use in alibre, to do this kind of work... :rolleyes:) but I think the construction procedure is equal also in autocad, or however similar.
Once the 3d spline is made, you can use it as a trajectory for an extrusion. (in turbocad I use the sweep function but I know that in autocad exists from the 2007 version).
p-h
bhe the usefulness of the link is that you can go to download your already beautiful spring that ready, and as it says stefanobruno in the native of your cad (peccato that there is not to alibre... :bekle:, so I have to download it in neutral format) you can go see how it was built.
we say that every cad exploits its potential to realize the various parts, in pro|e I can realize that spring:
- wrapping a sketch on a cylindrical surface and using the result as a traittoria for a vvs
- use a graph that will be the performance of the undulatura
- use a trajpar function
in alibre instead I do not have the possibility to project a sketch on a surface so I have to by force use a 3d sketch...
p-h
Hi, you would still have this prt to send me that I see how it is made because I really got too complicated the procedure you said and I couldn't. use creo7.
