unique inventor for various axioms
  • Thread starter Thread starter bobbino
bobbino
Good day to all,
It's just been working in the boiler room. . .
that uses boards out of scale in dwg happy all the aces.
so I was asked to have a unique distinction of many different assemblies, all contained from the same table, with progressive ball. .
Is it possible?
heartfelt thanks for the attention
you can get it done but the procedure requires a series of attempts and misfortunes that are difficult to explain only by writing.
is it a sporadic request or do you often have this need?
Hello, welcome among us.
because you don't do a superior set that contains all the axioms you need, practically a fictitious set just to pull the full bom.
Maybe it's your case.
Thanks stefano,
unfortunately in our sector has always been a requirement
that of the unique distinct, for various assemblies.
before everything was handled in dwg, and revisions are really
laborious, without counting inevitable errors of ballpointing:tongue:.
Right?
doing a super together was the thing I thought right away.
but I would like to manage the assemblies both individually (as appropriate tables), and
as composite boards. .glue the view from the single boards and putting together the various assemblies obtain a unique ball.
It's complicated, too.
can you put, if possible pictures as an example?
from what I understand I believe that the road of the "super together" is the only one that can be used, and even the least complicated.
you manage it like this:
1) do your iam by putting all your under assemblies in it, it could be the general layout, so you also have a view of the set of your plant.
2) in this layout, suppress all subgroups except one.
3) save the file with this level of detail (from a name that calls your subaxis )
4) repeat steps 2 & 3 until the completion of subgroups.
5) put your layout at the table by choosing from time to time the level of detail that contains the desired subgroup.
6) make your own distinct and stack, you should get what you need.
7) confirm that you got what you wanted:wink:
the above mentioned solution works by exploding subaxioms:
tools, document settings, separate structure,
Hidden. .
:rolleyes:
Hidden. .
:rolleyes:
is it a procedure for you to resolve, or is it sluggish?
I only ask you to understand if we can consider the case solved and store it in the dusty box.
(exploding or expanding sub-axioms separately? )
but perhaps rather than setting the assemblies on "hidden" just throw out a distinct "only parts" so you have the brutal list of everything you need to build your axiemon (expense list).
