unit in asieme due party....
  • Thread starter Thread starter maxray
maxray
hello to all....creo a set of 3 elements. two of these once coupled in the main axieme I would like to make them as a secondary set...that is, as if I put them in a set they are a single block.
I have to delete them, go out, create them together, put them in the main one and re-wine them with the third element ... or can I select them by binding them into a group directly from the main one?
But I hope you understand me....
thanks to the passage I look forward to your news....good holiday!
in a set you want to select a few pieces and make it a subset?
select them, right click, lower level, done......... if you are not using very old versions of inventor, the constraints between the pieces remain
thank you 1000 solved... :
- - - updated - - - -If you want, instead, to add details to the content center? Like a bearing or a screw created by me? :) thank you
you have to publish in a custom library, but the speech is a little longer because you also need to study iparts (if you want a well done job): I think it's better if you use the help online and follow step by step.
Remember that you can only post parts in the center and do not assimilate.
