I wanted to ask if it was possible to remove the measuring unit in changing a bond..... every time if you want to make a + 20 I must always remove the unit of measure (mm) represented. (solid edge 2022) Thank you.
maximum
I wanted to ask if it was possible to remove the measuring unit in changing a bond..... every time if you want to make a + 20 I must always remove the unit of measure (mm) represented. (solid edge 2022) View attachment 69781View attachment 69782Thank you.
maximum
