Hi.hi shiren... we tried to imagine how the forming cycle would be with the solution you proposed and we made a sketch attached. Is that right?
hi shiren... we understood the two phases you designed; but once you open the two brackets how can you extract the model without eliminating the sand contained in the concavity?the model is extracted
Hi.hi shiren... we understood the two phases you designed; but once you open the two brackets how can you extract the model without eliminating the sand contained in the concavity?
Thank you very much
Hi.hi shiren....sorry if we didn't get understood in the design that we had done but good or bad your last attachment was what we wanted to sketch. we thank you again for the help you are offering; We keep working on it and we'll get you back.
Thanks again
Hi.Bye to all,
: how much would a wooden model cost of the blade size (211x165x43) taking into account parameters such as working hours, labor time cost, raw material cost?
thank you again to all and... good game!
ok, I am already organizing the move and I am catapulted to work from your parts, before the prices fall to an unfair 45€ now :smile: !we estimate 40 hours of hands of work alive to 50€ =2000€
... how much would it cost a wooden model of the blade size (211x165x43)
shiren, I understand that the result of the game has slightly upset you:smile:, but there is no humming to consume a third of cubic meter to make a model of that size (but they were also four) . you want that there is a waste, but even if of models it is wrong ten in a row you need all that wood!....
The game is gone!!!!
for the material to use cirmol wood essence or pynocyrmolate essence cost to m.cubo 500/600 € to the supplier
There is a very rough way a good 50% in building a model is realistic to prevent 200 €
the hamster with the cured hamster?with the cirmolo you make a great grappa, maybe the discard should not be thrown away...
I saw that the grappa is really flavored with the lazy of the cirmol.ah not if he was aged, but he was certainly great.
If instead you used the wood (which moreover has an extraordinary perfume...) with that quantity of waste hypothesized by shiren you would aromatize us so much of that grappa to satisfy the body delgi aplini for four generations :biggrin:
I said football hurts. .
:hahahahah::hahahahah:Okay, I'm already organizing the move and I'm catapulted to work from your parts before the prices fall to an indecorous 45€ now
You're right, mine was a poetic license.I saw that the grappa is really flavored with the lazy of the cirmol.
Maybe it's the second one. putting limits on the thirst of mountaineers is like asking them to tell you when they are drunk.If instead you used the wood (which moreover has an extraordinary perfume...) with that quantity of waste hypothesized by shiren you would aromatize us so much of that grappa to satisfy the body delgi aplini for four generations :biggrin:
from the chirone-torncasa we read from table that says that for a piece of our size the foundry in coarse land has tolerances ranging from +/- 0.5 to 7.2 mm; how is it possible that changing only the material of the model would have a tolerance almost close to the worst of the range of the foundry on earth?but besides having huge tolerances in the specific case even more or less 5mm (the sum of which makes 10)
since ours is only a pure theoretical exercise we say that it is not expected that fusion is mistakenIf you miss the fusion the model no longer exists
Well, congratulations then!:hahahahahahahahah:
e' una Reale
shiren, I wasn't referring to the price of wood, but your estimate of how much it needed. . .for cirmolo wood
500/600 € per mcubo are at the supplier
you have to take it home!!!! ! ! ! ! ! ! ! ! !
