unresolved references
  • Thread starter Thread starter maior
maior
Hello everyone
My inventor makes me a little bit inc......re! !
I'm trying to make automatic conversion of idw to dwg for autocad.
for some files it gives me error "unresolved references".
I go to open them from the vault and actually even if I have no apparent errors
the icon "update all sheets" is always active or better: the sheets are updated (I see it from the browser on the left) but the command icon "update all sheets"
does not turn out...... .
How the hell do you see the references that "danno noia"?
thanks to all
never
firenze
I'm sorry, but I didn't understand the problem. :confused:
Usually, the "references that give boredom" manifest with the "resolve link" window.
instead of the table, try to open the represented items and activate all possible levels of detail.
Sometimes I happened that the vault made some casino with the synchronization of local files, so maybe try to delete the work area on your pc and try to open the drawing from the vault.
Thank you very much
but do you know where I find the command "resolve links"?
apparently does not signal errors the browser to sx(the leaf tree I mean)
"resolve connection" is not a real command. when you open an inventor file and, for any reason, you do not find a file to which you refer, a window appears, similar to that of explorer, who asks to search and select the file that is missing.
Unfortunately, that I know, there is no command that verify the integrity of an inventor file (...but I hope I will be denied! )
