Unselectable view
  • Thread starter Thread starter deba7171
deba7171
I have regenerated a table and in the arrangement of the various views I find a partial view that I cannot select to be able to eliminate it. (see image)
probably went into crisis because he no longer finds the references asked.
as it gives me problems in the dwg conversion of the table, how can I delete the view if at video I can not select it? Is there another way to delete it (type : remove sheet no...)?
I have no idea what the cause is.. .
But a solution could be this:
Create a new sheet, select one for one of the views you want to store...and from the edit menu select "move item to sheet" and type the number of the new sheet you created.
At the end you will have two sheets.. the first with only the view you cannot delete and the second with all the views you need. you just have to delete the first sheet.
thanks alberto.e.
perfect solution. now the incriminated view has been eliminated with the first sheet and generating the dwg no longer crashes.
You saved me a good job.
Thank you
Staff online
