unselected images in autocad
  • Thread starter Thread starter flynight
flynight
good morning to all, I have a problem with the selection of an image in autocad.it is a cartophragm on which various windows have been realized each containing a different sheet of cartography. in my case I went to the layers and opened the window representing the part of cartography that interests me.I checked that the layer is active and not frozen but despite this does not appear the window but only its content.So I can't move the image on another file...how can I do to recomparise the window? I also tried with the _imageframe command setting it to 1 but nothing.
I honestly didn't understand the organization of your design very well... I can't understand the relationship between window (viewport) and image. . .
still moved to space model and locate your image and try to select it.
also controls the blocked layer status.
to the maximum control also oleframe not to be 0, if some crowds have inserted the image of a cartography as an object...
I checked the oleframe command but it's not set to 0. if I go on edit, edit, image, the window comes out, then then it makes me select commands including on,off,new contour and delete contour.I tried them all but I can not copy the image
Uhmmm... blocked layers are not... the variable frameselection Is it 1 ?
if you have to copy the image in a other design usa copy and then (in the design of destination) Paste clips
