update error
  • Thread starter Thread starter marcofa
marcofa
after I built a part, I ran a pocket by drawing a sketch on a part face.
If I change the part, I don't recognize my pocket and a diagnosis message appears.
asks for the modification of the definition of the absolute axis.
I don't know what to do.
Mar
Mar
It's impossible to understand the problem.
Can you tie the catpart?
you should understand what you mean by x modification of the part......... because if you delete a face where there was resting the sketch that jumps.............
cmq right button on the object sketch and change the reference of the sketch
this gives you the opportunity to give back the reference to the sketch.........
............ for so little:biggrin:
cmq if you "pasticci" a little with that command you can use it for many other situations:finger:
