update problems (sister)
  • Thread starter Thread starter marcofa
marcofa
from a few days I have a problem doing the upgrade of part positions in a product, after having moved them manually.
When I click the spin the progress bar appears, which flows quickly up to 100%.
at this point everything stops for 30" or a minute before upgrading and computer fans accelerate by indicating a overheating from work.
I have verified viruses and what else but nothing changes.
aid
Mar
1. reinstall catsettings and do a test
2. do a cadua fui several files and do a test
made catdua but changes little.
How do you reinstall catsetting? how do you not miss all settings?
Mar
Mar
Hello, Marco.
take the folder of catsettings in c:\documents and settings\stefano\dati application\dassaultsystemes\catsettingsand move on the desktop.
You start caia so it creates you new catsettings.
see if everything works otherwise you override the newly created folder with the 'old' catsetts you have in your desktop.
something has improved, but there are still delays.
for example by applying a constraint pass about 15" before the window closes, and also the update is delayed.
a clarification: of course all my stunts are lost and I have to laugh again?
Mar
I made a very strange discovery.
These slowdowns happen in a pip set that contains various subaximes.
I also have another pluto group that contains a subassieme minnie in common with poplar.
Now. .
If I make shifts or changes in pop minnies I slow down, if I do the same things in pluto minnies it's all regular and fast.
Mar
Now. .
Mar
Do you have any active bindings?
slowdowns usually occur when you have entities connected between parts or product
if you mean external references, yes some, which in pluto instead are not there.
but is it possible that some external reference between parties not involved in the update may have such disastrous effects?
Mar
At this point I believe that by analyzing the logical tree, something not necessarily correct...
Mar
you can attach everything:finger:
after a little computer holiday turned off and forgotten today the problem no longer arises. mystery. Maybe even PCs are stressed out! ! !
