update table holes
  • Thread starter Thread starter Daniele-san
Daniele-san
Hello.
I have added holes to the existing model, but I can't make the new holes appear on the hole table.
I can't understand why
Can you help me?
Maybe the new holes start from the opposite floor?
hinges
I thought so, but it's not like that.
I believe a bug of creo 5 because without touching anything I restarted and remade the same procedure and added the missing holes.
I wanted to ask you if you know what are the config paramentaries that go to change the size of the table and text (fonts etc.) inside.
I usually do it manually at created table
parametri tabella of *.dtl:
default_table_columns #
default_table_column_width #
default_table_rows #
default_table_rows_height #
il testo è quello standard del disegno
Arni
