update view raster.... non-existent!
  • Thread starter Thread starter Matteo Cappelli dis.CAD
Sometimes it can happen via the dx button, to raster a view in a table:
_foto__158.webpBut today, something strange happened to me:_foto__159.webpboth the view icon in the browser (red bar) and the message, lead to think that the problem is rasterization, but the command of "perfect view", is not active.
known that the current view icon is activated and updates all sheets.... but by clicking, nothing happens and remain active. The other views are ok
help?
try to select one to one views in the browser. Maybe there's something flagrant about you
Thanks for the answer. I found the cause of the problem (although I did not understand why).
Turning off a part from the view where there was the problem, .... solved: the view has been updated.
strange thing: the other views were ok; the incriminated part is a 3d model downloaded in stp format by a manufacturer of electric motors and imported as multybody, so nothing strange, a solid without surfaces . the problem also presented itself different time ago with another model of engine.
Another strange thing, table 2d in which there is the problem, is a group of the main machine, which is then mounted in the machine, but if I open table 2d of the machine in which the engine is again seen (which clearly is no longer at the first level as previously) but the various views show the same "graphic", the problem is not there!
