updated massive views in idw
  • Thread starter Thread starter samurai76
samurai76
Hello, I have a difficulty in managing updates of the views of the masses in the plant.
when I modify the ipt files connected to the various views I created in the idw file plant masses, the editing information is received but it is not automatically applied in a massive way. I have to click with the dx button on a view that has the yellow flash and select from the "upper model" drop-down menu and I have to do this for every view present in every sheet of the idw(see printscreen allagto). so if there are 10 sheets with 5 views each work becomes honorable.
Can you tell me if there's a way to simultaneously confirm the update on all the views?
Thank you for your patience
Test :
tools --> application options --> design --> remove snack to " enable background updates "
thanks stefanobruno for the straight. I profato to remove the check and I also restarted inventor but I must always update a view at a time
Test :
tools --> application options --> general --> physical properties --> put the check on " updates physical properties during rescue "
What's wrong with you?
Thanks again... I will try Monday because tomorrow I am not at work.
my pc is in i7 with 8gb graphics card envy 4400 picture with win7 pro
hi stefanobruno, I also tried your second advice but nothing to do...I always have to update a view lla volta.. .
...I don't know if it can make a difference but the views I create are derived from an ipt with ipart. .
