urgent: how to import written in 3d studiomax
  • Thread starter Thread starter jox1981
jox1981
Hi, guys. I just signed up.
I searched with google but found nothing:frown: the question is this:
When I go to 3dstudiomax I click on import, I care the dwg but where there are the writings (of the codes I need absolutely) there is an empty space!How can I in 3dstudiomax import also autocad writings?? ?
I hope you can answer me because if I can't be in trouble :frown:
Thank you so much!
Explode the writings so they become autocad lines, then remake the import. If you want editable writings use the text of 3d studio.
What? I don't want any editable writings, thanks to the explanation, but you can't explain it step by step ?I have autocad 2009 :confused: it tells me that it can't explode the lyrics !!! but you tried to explode the lyrics in autocad and import them into 3d studio ???
I don't think you can explode a text... if you get out of the dxf and it amounts to it max?
to explode the text you need to install autocad express tools and then use the txtexp command
azz. casino !!! on another site told me about these express tools :frown: but I thought they were already included in autocad 2009 :mad:
to install the express tool go to control panel
disintelligence of a program
autocad selections
click on uninstall\cambia
add new functions
selections of express tools
Good! and since on treddi.com they told you express tools instead of trying and finding the solution enters another forum in search of the miracle, making it waste time to people. try to use a little more google and ingenuity and a little less the precious time of others. :mad:
You're right, I took it for granted, I did it several times, but I didn't remember that they had to use express... .
Thanks for the answers, however I was in a hurry and so I counted the various blocks without importing the writings, unfortunately I had a deadline!
+ 1
