urgent-i can't open 2d
  • Thread starter Thread starter Cla
Cla
Excuse me, but it's very urgent. I don't know practically anything about unigraphics, I just have to convert files including a 2d that I would like to convert to dxf. But when I try to open it tells me that there is an error even if it shows me the preview... do you know how to fix??
The error is this annex
if you're trying to open the .prt file with autocad it's normal for you to get the written one
If instead you appear the error mess by opening the draft with unigraphics then it may be that your software version is not compatible with the version with which we have prepared the drawing....
Try to do something stupid.. .
put the file in c:\ rename it with an 8 characters name and try again to open it. . .
It's not going to work, but I meant to say my...
I press that the files below are personal and not professional.
It will change the penalty, but the fault remains the same. . .
If the "parallele" euphemism underlies "pirata", you have wrong place...
So to stay with us, I think you have to change your register. . .
if unigraphics does not give the possibility to use the same license also for a second copy for personal use, then you have to hunt the euro...
you are right but I would like to understand how much it costs me in terms of euro to buy a license (or all software, I don't know) considering the limited use in the time of the second installation.
I think we start from 10,000 euros to climb.
Bye.
p.s. Could you upload an error screen? just to see if it's the classic error or they changed the message.
I don't know the sw you use and I wonder: is there no possibility of exporting the license to another pc?
so you would have no problem with " parallelism " and we would all draw a breath of relief (see the pebble pulled in the forum ).
Bye.
for the second installation you can use the borrowing.
ask your reference business, or if you have the borrowing license, please contact the hotline for info on how to use it.
However I use version 6.0.0.24, the original version (with which it was made 2d) I do not know it,...
6.0.0.24? It's the first six. (normally it is the version on which the "parallele" versions are built).
upgrada to a newer version: definitely helps.
