use and operation of the universal milling machine differential divider
  • Thread starter Thread starter odisseo 18
odisseo 18
you could explain to me how it works and how to make calculations of the differential divider x milling machine thanks or to recommend the right book to consult
Nice tool. the principle is not complicated if you are used to working with gears. At the time of theitis, I struggled to deal with it.
look at this guide that explains and calculates typical things http://www.itis.arezzo.it/index.php?option=com_docman&task=doc_download&gid=2547&itemid=222.
Alternatively you have to find a manual of a divider and read it all.
works as a circular and allows you to make fractions of circle as long as you get the desired angle by composing the various disc circumferences with different divisions.
thanks for the information and your availability, unfortunately I did not have a master who handed me these knowledge, can you realize cams with the divider? for the racks that system is used?
the formula di riferimento dovrebbe essere questa giusto:
40:2xf; 40:nxf
x=40:nxf
x:f=40:n
x=60xf:n; x=dxf:n
the racks are built with the cutter to form and are to be moved of lazy x module to be able to make each tooth compartment. So the divider doesn't need anything.
to make the cams it is possible to use the divider to be able to sink with the vertical axis of the quota set in correspondence of the angular rotation set.
when I was making racks with the universal milling machine I set gears for automatic pasts or with the comparator melt the steps.
