use design accelerator
  • Thread starter Thread starter Bidaniele
Bidaniele
Good morning
use recently inventor 2014
I have some problem with the use of the accelerator design.
the problem is not to draw the object (shaft, pinion, gear etc. ) but it is on file management .
For example I noticed that the generator of a tree creates two drawings one of a set and one of a part.
do I have to give the code of the particular code?
do you save him once again? ? ?
all acelerator design components are generated in this way.
what you will need to codify or modify iproperties for managing the separate will always be the part file inside the axieme. in fact if you check the properties of the assieme you will see that as separate management will give you as "hidden".
thanks for the answer . I wanted to make an example
I open my project name pippo
I create a tree with designe accelerator
inventor creates me a pippo folder, a subfolder design accelerator and two files, one part and one together named tree 1
But I would like to give a numerical code to the tree ( should I give it when I save the file??? ? )
Do I have to keep these folders or can I place the files where I want?? ?
thanks daniele
