use of cartilages
  • Thread starter Thread starter Petruz
Petruz
I press that I don't know autocad or at least used only version 14 when I went to school.
I would need advice, normally when you have to make cards which have editable fields as you proceed:
1-use blocks
2-you use layers
3-It fits as explosion in drawing
Thank you very much for your precious advice
petruz
thanks tristan
I'm sorry for my ignorance, but this is true for both Autocad 2d and 3d right?
petruz
I know that the cartouche is only used for 2d representation is that not knowing the program I did not know if the settings for autocad purely 2d were equal to those of the autocad 3d.
you know autocad 14 that I used was only 2d and now I don't know if the 2d and 3d are two separate programs that can be purchased separately or not.
anyway thanks for your advice
Good evening
petruz
I know that the cartouche is only used for 2d representation is that not knowing the program I did not know if the settings for autocad purely 2d were equal to those of the autocad 3d...
you have to use the files in the layouts.
...you know autocad 14 that I used was only 2d and now I don't know if 2d and 3d are two separate programs available separately. . .
same program (then there is a distinction between full and lt).
