fabry56
Would some good soul tell me if with proe wf2 it is possible to quota in the draw two neighboring rays with one quota and two arrows? I see you can only do it with notes or am I wrong? I can't do it right now!
Yes, I confirm that you can only do with notes (which I know) and then enter the string relative to the radius quota(for example &d379 ) so that you update the data if you make a change.hello to all.
Thank you so much!Yes, I confirm that you can only do with notes (which I know) and then enter the string relative to the radius quota(for example &d379 ) so that you update the data if you make a change.
bye maxopusYes, I confirm that you can only do with notes (which I know) and then enter the string relative to the radius quota(for example &d379 ) so that you update the data if you make a change.
when you create the note normally insert into text.bye maxopus
I'm sorry to bother you, but I don't know where to write and insert the string.
Unfortunately, I never did this.
You know, I'm a little old and I'm starting to go.
