use spl2pl.vlx on autocad 2013 for mac
  • Thread starter Thread starter fiddleman
fiddleman
Hello, I downloaded the file spl2pl.vlx but autocad tells me that I can't load it. I only charge .bundle, .crx, .lsp, .dbx and .fas
How do I do that?
What command are you using to charge the vlx? Don't appload, do you? what version of autocad are we talking about?
yes, I tried appload, but also knows tools -> charge application, but it does not charge the extension .vlx
I use the 2013 version for mac.
autocad for mac does not support vlx, I'm sorry. if you just have to convert a polylinea spline test with the editspline command.
Okay, I'll try, thank you.
I wanted to bring to z 0 all points because drawing the spline in the front window looks exact, but then looking at it all go around...
I read that turning it into polyline. how do you draw frontally holding the z to 0 points in the plant?
if converting it into polylinea is something on which it becomes impossible to work:
splines
polyline
What am I supposed to do?
