Okay, but what do you have to get more or less? Has wert taken us or is yours another need?that is a surface, and I have to create a solid body, with thickens it does not work because they are convex curved surfaces and intersect
thank you but I don't have it in the company!!!! I also use solidworks at home and the models,inventor does not need to treat surfaces, even at a minimum level, you have to use more.
I use rhino for my needs, then I continue the design with inventor.
do you have the freeform tools in inventor?thank you but I don't have it in the company!!!! I also use solidworks at home and the models,
