user interface
  • Thread starter Thread starter citri
citri
Hello everyone
as every year, with the release of the new release I present the same problem for customization of the user interface.
practically already last year, with 2010, I had lost more than one day to set up the All-In-One bar (command position, icon size, etc.) so that I could easily find all the commands.
now with 2011 I wanted to load the configuration of 2010, someone knows how to do??? :confused:
I haven't installed it yet... but have not attached a utility to import menus since 2010?
after tests and tests I managed to do the job in half (so I don't know if I did it right)
I practically took the .cuix file from the 2010 version and copied it and subsituated it to the acadm.cuix file contained in the document and settings/user/data applications/ecc after which I went into the 2011 mechanical options and the file entry, I assigned the path of the .cuix file to the voice "personalization file".
I say half because the All-In-One Bar actually shows up as in 2010, the commands are there and all work, but many icons are quoted with a "?" inside a cloud, I checked that the name was correct, etc. and it is right, only that even in the list of icons, half there are always "?" (it is as if it didn't find them ...:frown: ), if instead I open an original .cuix file of 2011 the icons there are all
What do you mean? ?
I had tried to do a similar process (obviously wrong) and had created a hallucinating chaos between icons, commands, etc.
in 2010:
options -> profile board -> export current profile
and in 2011 the reimporti.
solved! Thank you very much!:finger:
I practically exported and imported the profile, after which I also copied the acadm.cuix file inside the autocad mechanical folder 2011\r18.1\ita\acadm but I also added the acad.mnr file (autocad menu resource), I don't know if it was really the problem though doing so I solved it:wink:
there is a utility to import or export custom settings but it is for the same version and not for example from 2010 to 2011. Now that I have everything in place anyway, I used it if ever it should serve me in the future:finger:
It's true! It's a mistake I made with 2010 when I was convinced that there was...
Will it be the good time I'm thinking?
If I'm not mistaken, several versions ago there was... maybe to move from 98 to 2000?
The thing is, I never served, so I never even started it. . .
I don't know in the 2011 version because not yet install it, but at least until 2010 there is the utility "exegui migration from a previous version".
never seen :confused::confused::confused:
on my 2010 there is the migration of custom settings (but always from/for version 2010) and at most there is the migration utility of mechanical files.
on the other hand I can no longer uninstall version 2010, from the application installation window does not open the page (that with repair, reinstall and uninstall) :eek:
but that's for .dwg... not for personalizations. . .
That's why I got confused. I had read the name and thought it was what there was many versions ago dedicated to settings and menus...
I actually started it once a long time ago (and one now that I installed 2011). .
I confirm that it is for custom settings and not for imports of dwg. allego screenshot.
at least in autocad and map 3d is so. It seems strange to me that he is not present in mechanical.
boh :confused:
in mechanical there is only the one for the dwg and the one for the settings of 2011...
Maybe I'll ask the autodesk. .
for how mechanical use I have no problem... Just that ten commands work, and I'm fine. on inventor the speech is different... :36_1_1:
