vacuum volumes calculation
  • Thread starter Thread starter and
and
Hello, is it possible to know the empty volume of a group?
example if I designed a tank, how can I know the free internal volume???
I think it's impossible.
the mathematics below cannot "recognize" the vacuum surrounding the object simply because it is not a feature.
You have to do it for difference between the full solid and the dug one.
I hope I didn't say a cretin.
I probably understood badly, but just draw a parallalepipedo, called volume for simplified, slightly larger than the tank and remove all parts of the tank group. at this point you will have a number of parts from the volume name, volume.1, volume.2 etc., of these eliminates all parts completely outside the tank and finally calculates the volume of the remaining.
if in the tank you have open holes, you must have the kindness to cut those parts by separating what is inside the tank from what is outside.
Good morning, I'm a DNA with my computer. I have in mind to produce a plastic object as I calculate the amount of polymer that goes into a mold
I think more than worrying about the volume you should first check that the mold is treated with the proionic slap, if it is there are no problems, otherwise you should add +0.02% but then the sform angle?
