valori di default
  • Thread starter Thread starter pagatti
pagatti
can you change what are the default values of inventor work?
For example: create hole, the default depth value is 8 mm, can you change it?
or is it possible that the standard hole is passing (depth "through everything" ?
or, if I make a threaded hole, the default value is m0.5 or so, to find m10 I have to scroll all the curtain.. .
Perhaps this can be changed by changing the order of rows in "filettatura.xls". . .
If someone knows something... thank you.
that I know the only thing you can change is the default size of the threaded hole. just in the .xls file move your hole to the first row. I don't think the other values can be set.
I would also like that by default the hole was passing, and I add, in quotation the tolerances in default= bounds / couplings stacked and both in n/a,
or that the various dialog boxes remembered the previous input, but not always do.
from this point of view, inv is rather coccite :3559:36_1_10:
Does anyone know if there is news in the new versions on this front? it bothers me to set up every time certain "stupid" values, bevel type at 1mm instead of 2, etc. etc.
not to duplicate the message I add the following arguments that are part of the default settings.
1) Why is browes often opening a new ipt/iam file disabled? (demands slightly ot) or at the opening of the same is disabled.
2) how to set a default material to creating a new part instead of generic.
3) set a bevel value and radius .
4) set and leave welding thickness stored (this in idw)
roberto
roberto
1) never happened to me, but I think it depends on the interface settings in sight -> user interface, but as I say it never happened to me and I can't make it happen
2) open the standard.ipt or sheet.ipt template, set the material you want both by default and saved. when you make a new part it will be of that default material
3) this is the topic of topic and apparently you do not know...
4) If I understand what you mean, you have to set it as default value in the .idw style editor
