valves plants
  • Thread starter Thread starter Tullio01
Tullio01
Hello everyone,
I wanted to ask you for help with a problem......according to you it is possible to reduce the input flow to a battery of a air conditioning system using a 2-way valve....according to me it is not possible, since with such valve I can reduce only the incoming preesion to the battery, but the flow rate is not necessary a 3-way valve....however if you have any suggestions on this or if you think it is possible to reduce the flow rate... .I am open to all suggestions...... thank you very much!! ! !
if the law of preservation of matter also applies to your system then vary the pressure but not the flow rate. to reduce the flow you need to increase the section for the law:
volumetric flow = area * speed
I hope I'm not wrong
