variabil
  • Thread starter Thread starter Anothermatt
Anothermatt
Does anyone of you know how to answer my question, given a compound of 10 parts, if I have created in every part a varable to which are linked the sketches of the geometries that interest me that they vary, you can sucessively link this variable in the environment together and manage it from there, thus managing the complete axieme?
Thank you very much
Thank you very much
"noob alert"
for what little I know, if I understand what you mean, you can manage configurations in the axieme by pressing on the single component and selecting the configuration you need directly from the menu.
I am quite convinced that you can create configurations for axioms but it is a process that I do not know and for what I do my method is more than enough, massivonweizen evoco you!
I don't think that's possible, but I didn't get into it.
instead you can insert the variables in the axieme and then return them to the parts.
For example, the variable length is inserted and gives it a value, then double click on the function of the part, you enter into the editor of the quota, you write equal and a drop-down menu appears including the global variable voice with the list of variables; all this, however, must be done from within the axieme and without changing part
Thank you very much.
I was aware of the government procedure varying from environment together, I wanted to understand if there was a way of linking them.. I'll work together. Thanks
:smile:
