Joshua662
I take the opportunity to wish you all a good year of the community, I would like to expose my problem, I should realize a cochlear for material transport with the surfaces because my cochlea is not as many that are around but has a particular form, in fact there are two points that diversify it from others:
1) and variable pitch
2) between one crest and the other is connected with variable radius
Have you ever dealt with something like that? I cannot attach images, an example that could lead you to imagine this object is the coclee of the meat grinder or tomato squeeze, it has the same center of mine, with the one difference that is bigger size, and the radiation at the end of the coclea almost one with the crest. do you have a tutorial to follow or some free manual that is on the net since one has made a small handbook to explain the catia surfaces type tutorial? in waiting for your welcome answer I offer my most cordial greetings.
