Tekkasoft
hello to all, I have a problem that maybe it is simple to solve but, it will be the heat, I can't.
I need to draw a simple section along a 3d curve.
the problem is that I can't digest the variable section sweep tool (with constant section)
a chain of curves derived from two curves that have as reference two points in the cadauna space, and a sketch curve,
designed on a floor, which is connected to two of the points of the previous curves.
to speed up I attached the file (wf5).
I trust you. . .
I trust you. . .
