nickobellick995
Hello, everyone. in solidworks I defined a material library with a specific code (e.g.: #001; 0#002 etc). in the properties of the materials, in the sheet board, I used the option 'Table Thicknesses' and I selected a excell that I created on the false line of that present in solidworks called 'sample table - aluminum - metric units' and when I create a new sheet (after setting the material in the document) enabled the item 'use material sheet parameters'. the problem is that the Excel is read from the software but the thickness of the sheet created does not vary.
Basically when I create a sheet and I give you a material I would like to ensure that the thickness of that sheet is automatically the function of the material I have selected from the featureworks and then going to change material the thickness of the sheet is suitable. I train you the excel I created.
thanks to anyone who answers me, I hope I've been exhausting in the explanation.
