roberto
by running a command without help functions, as it moves, the "opens" pane appears even when there is no set help function. can you disable and how or is it just my problem?
always on the 11 I noticed that the text string that you go to change with the old "change" command no longer enters all in the box that allows you to make the change, when the text is rather long. Is there any variables to set? :redface:
