various questions
  • Thread starter Thread starter SvenCad
SvenCad
Good morning. My name is diego I am new to the world of cad. I have some questions for you
1) is it possible to move from one layer to another?
2) What is the difference between the delete and purge comnades?
3) the difference between layout and paper space and if you can create entities on paper space and model?
thanks to all for the collaboration
1) select the entity and through the layer board or entity properties select the new target layer.
2) delete erase the selected entities, purge removes from the design all that is not used (layer, blocks, quota styles... )
3) you can draw where you want, but the correct sequence (except for special needs) is drawing in space pattern rigorously 1:1 also details, sections and other, setting with cartiglio in paper space or layout that are the same thing using the fnestre to properly scale the various views
Thank you very much!!1 all very clear, they seem discounted things but for those who are at first a moment they have to get in the head!!! !
