vary angle measurement approximation.
  • Thread starter Thread starter malamente
malamente
what settings do I have to change in the wf2 to have the measurement of an angle (menu analysis-measure-angle) in degrees, first, second rather than expressed in just degrees?
For example, an angle of 8°10'30'' is expressed as an angle of 8°, too gross approximation for my work.
Thank you in advance.
in your config.pro (instruments > options) you need to set your options properly:default_ang_dec_place
ang_units
angle_grid_interval
ciao.
ang_units
angle_grid_interval
ciao.
done, but those options only changed the odds, not the information given from the menu, analyze-measure-angle
at the end, changing (PHP 4 = 4.1.0) I got the desired result.
I find it strange that wf2 allows me to view angles in grades, first, second in odds but does not give me the chance to enter angles if not in decimal degrees, for example in the creation of datum planes, always obliging me to carry out manual conversions.
Compared to linear quotas, angles seem to be treated as children of a lesser god.
Bye.
