vault basic import existing projects
Emc2
hi audience of inventor users, I would like to start using vault basic version
I created the vault project with the definition of all the parameters identical to previous projects (path styles and libraries) but I can't import the previous projects as I have to do in the project?
I have to copy the project in the area of l avoro vault and import it from that path (holding that I have to make every file name unique .. that ball. )
or there is a folder import command, which I did not find, which moves from the existing project folder to the vault folder the project. I have only one project file and I have created several folders that contain the works I have performed these years (about 60gb of stuff)
you do not have to import projects (models,tables etc) into the vault project but into the vault environment.
in practice on the server where the vault works
