vault client 2012
  • Thread starter Thread starter ghiddo75
ghiddo75
I first installed the vault client 2012 for inventor. when I login asks me server and database; Would you tell me what you mean by these rumors? considering that I am the administrator and that my workstation is not on the network with other computers or servers that contain licenses
What do I have to insert? and on databases? :confused::confused
I press that I have never used vault, but I think I can say that it is a software that allows the sharing of projects to multiple users on the net.
see more detailsIf your pc is not on the net and you are not part of a working group, what are you doing with vault?
the vault is a program that is used to manage drawings including migration from one folder to another by copying the drawings without losing ties to the various axiemi, it is used to manage the projects by transferring details from one side to the other without creating cases etc. so even without a working group is still fundamental. yesterday I tried to login by entering as administrator username, in this case it is not necessary to introduce a password, while as server I tried to enter localhost but exits the following error message:
"autodesk vault 2012 is unable to detect data management services in localhost."
Can someone tell me why?:confused: as an alternative? :confused:
the vault you installed is "client".
to use it needs the "server" you will need to install separately.
if you install it on another machine on the network you will need to give it the coordinates like the name of the machine or its internal ip address, otherwise if you install it on the same machine where you use "client", then you can also write "localhost".
first you need to install the vault server though somewhere.
Yes, you can install server and client vault on the same machine and use it without other network stations, of course you need to assess the impact on performance since you will always have the sql database running in the background.
If you work alone, offline, I'll give you the vault, it's a pdm that's used to manage joint projects for multiple users, maybe spread over multiple plants. . .
vault was born for collaborative environments, but in its basic version it also goes well for single-user posts, simplifying not little the management of parts and together with relative dependencies, without being bound to the classic organization on hard-drive, as well as semplicating the reuse of components and massive operations on files (e.g. management of iproperties).
in general allows you to work without worrying in the first instance where to save the file, how to codify it and various properties, the work space becomes a simple support area for the "brupt copy", then reorganize everything in vault.
Obviously it imposes a different method of work and management, it is up to the designer to assess whether it is more practical and productive to independently manage its contents or rely on vaults.
certainly vault then has many other specific features for shared work, but this does not prevent its use in mono-user posts.
clearly this is my simple point of view.
hi yarin voodoo
I would like to try it, but how can you install vaul basic on your pc? I am still standing at the problem of ghiddo
Angel
