vault su singolo pc
TECNOMODEL
as from title I would like to use vault basic that is included in the inventor license on a "single" pc, not connected to a corporate network.
this to have available storage tools, rename files, move them etc.
was installed together with inventor but not configured.
first, can you use it like that? Maybe by configuring an external hard drive as an archive.
if I open the vault asks for a psw, also from a mistake because it cannot connect to localhost.
how can you enter the configuration by jumping this step?
Is it a work that can be done by a simple cad user or a specialist to configure everything?
it is not impossible if you read the guide and you have some familiarity with the installations. (I used it on my pc just for your own reasons)
Know that what you have installed now is the client side vault. you also need to install the vault server and then "talk" it with the client and inventor.
I would not use it with an external hard drive, but with a partition or a folder directly below c:\
then on external hd I would only make backup.
maybe feel your dealer: if they are honest in a few hours they install it and configure it. then a couple more hours for a minicourse.
thanks x le info.
You say you used it the same way, but now, I understand, not anymore.
Do you use a different method or are you in a business network now?
If there's an alternative to the vault I'd evaluate it, which if I think it's hard to have those tools and those security.
I use the professional from the 2013 version manages very well links, automatic coding, rename various files, search, then I would stop here, for everything else always has some kiss or limitation .... I've never used any other software like this, but with hindsight, I don't know if I would still use it... .
thanks x le info.
Now we're two technicians. installed the vault server on the server and we use the client part.
we will soon pass to the professional version that has more functions, but for what you have described you is sufficient the basic version.
I'm looking inside the autodesk account but I don't find vault server.
I really don't even find vault, just the product design suite but inside I don't find vault.
you have to go to the "product improvements" section then look for autodesk vault basic and you will see this window for download:Vault.webp
you have to go to the "product improvements" section then look for autodesk vault basic and you will see this window for download:View attachment 43359
already done but I can't find it.
I have seen on other forums that is a frequent problem, it seems that since 2016 the possibility of download is no longer present.
should be in the installation key, as soon as I have some time I look at it
