vba e scroll bar
  • Thread starter Thread starter reb_bl
reb_bl
I have an inventor vba combobox with drop-down menu that is too populated, I put the limit to the window so that the vertical scrollbar is activated and so far, all right.
scrolling with mouse wheel but does not work.
I tried to google, but the examples I found don't work, or (more likely) are I who can't make them work.
Do you have any plans?
I don't know what I'd give to learn how to make a combobox in vba
can you give some advice on texts to start?
Matteo, please tell me about you!
I can say that the help of the vba is very well done and on the net there are many cases similar to that in which you come across: I started like this, but I'm very far from a programmer!
Let's say I play, here in the forum there are people much smarter than me!
I confirm that the wheel does not shake.. .
I found this, I didn't try it and I don't even think about it:p:https://stackoverflow.com/questions...serform-form-does-not-scroll-with-mouse-wheelfor programming questions always check the stackoverflow forum if you don't already, usually someone already had the problem and someone else solved it, an information mine. . .
hi catafract, I had already looked, unfortunately I had already looked, but apparently with the 64 bit version does not want to know to go.
@matteo hats dis.cad , @catcher He knows more than I do!
