vectorworks poligoni docfa
  • Thread starter Thread starter archiwalter
I still use vmware fusion, but I have seen that with the latest virtualbox versions it has made remarkable progress and although I do not think that at the graphic level is equal to fusion or paralles, I think it could be enough for the use of which it was spoken (dwg, docfa/pregeo).
Scusa, ma te son furlan o triestine?: -d
And I thought that you might not have given me that you pray... are Trieste emigrant. .
mandi frut!!
However since mac have intel processors it is possible to turn windows xp without particular problems.
indeed, without problems at all.. the only "difficulty" is to follow the installation procedure.
I'm sorry if I'm back on this.
(It's always me, I had to slightly change the u.n. as I could not read myself.
I placed my problem with videocom support and kindly asked me to send him a dxf file obtained with acad containing the infamous polygon layer (of course a file that docs 4 amounts correctly), in order to be able to study it and propose a similar solution for vector.
Does anyone have a chance to send me one?
Thank you!
Of course, in case of solution of the problem, I will not miss to inform all interested parties!
