lory.b
I don't know if you're evaluating the Italian version or that international version so I'll use double names.
vectorworks files are structured through classes/categories (equivalent to acad layers) and layers/glosss.
the latter are to be considered containers, spatially defined by attributing to them a ζz. parametric objects, such as walls, can automatically take the heights of layers/gloss.
you can initially set up a series of layers/glosss in succession, at heights and equilibrz established, from the foundations to the roof (start function).
each layer/glosss can live for itself: I can keep it visible, make it grigetto (not editable) or turn it off. I can see them and turn them all together or isolate one to work without interference.
I don't know what you mean by bim assistants, actually... I still hope I've given you at least one idea of the basic approach.
on the nemetschek website you can find material with explanatory examples in the "bim in practice" section http://www.vectorworks.net/bim/index.php
lo
lo
