vertical text (quotatura)
  • Thread starter Thread starter brasiliano
brasiliano
Hello friends,
a doubt:
how to make a vertical quotation appear with the vertical text, i.e. above the line?
in the design options (file>properties> drawing options) you must set the angdim_text_orientation option on parallel_above.
if you want the default relocated to save the options file on that bed from your configuration (config.pro).
Thank you. ..perfect!
to mix (horizontal/vertical) is possible?
do you want a single quota to have the text both vertically and horizontally?
Forgive me, but I still don't understand.
I'm sorry. I'm sorry. .
So... .
on a table, this a front view that I want to quote only with text in orizontal and on another view (lateral) I want to quote only with text in vertical.
is it possible to do? ? ?
