very deep.
PaoloR1
I apologize in advance if this is not the section of the correct topic, but I did not know where to write.
I designed a particular joint, and the ideal as processing would be to perform a stud. the problem however is that it must be very long, about 1100mm. some of you can tell me who can do this type of work.
Thank you and hello.
Palo
if it is feasible you can do it with a peeling. are not many companies that still have one in the house of the hydraulic ones but could go well provided that it is not blind processing
it will not work with 32bit xp any new version 2.5.1.
i was able to install, but when you try to open a new file to launch
will fall.
Bye-bye
how deep is the foolishness you have to create??? a workmanship similar to your own.. is created in 2 half due to the length.. the created throat was about 2/3 mm deep..
