costruzione3d
Good day to all
for simplicity of construction distinct base etc... I have a plant derived from autocad, but I converted into jpeg and I inserted it into the ipt sketch of inventor.
I was forced as the dwg plant feeds the 30 mega... ( already cleaned up etc... without having appreciable results)
I have machine walls. . all I need and with the visibility of the sketch also the image of the plant.
I go to the paper space and I have the problem that I can't view the sketch of the ipt of the plant file.
It is true that I can export it to dwg and with the due references overlapping it to the old autocad.. But already I was in 3d I wanted to have everything underhand. .
someone knows if you can then view sketches on an ipt model, where this file is inserted in an iam.. and in iam paper space view ipt file sketch?
Thank you in advance!
