view "intimate" (house) super small, far
  • Thread starter Thread starter pizzaf40
pizzaf40
Hello, everyone!
use inventor at work for about 8 months. with the last project I happened the following:
- I opened the .iam of the assieme machine in the morning and the basic view justified (click on the top right cottage) was a smaller, far, than usual thread;
- from day to day more and more, every morning worse, farther... and the car began not to see itself;
- a nice day I enlarged, centered, right click on the cottage -> current view tax as start -> default distance;
- this last operation only applies until I work in another together or until I turn off inventor and turn it on again. and in any case it only applies to the cottage, not to the views obtained with the cube, which continue to be far away.
Ultimately when I open now I have a dot far away, beautiful centered, that I have to zoom 3 times to see it well (with zoom window, not with scroll because the axieme is heavy and with the scroll is slow for graphics).
I add that I do not have distant pieces in sketches (controlled and recontralized). Moreover, if there was this problem, it would be very likely that the machine is moved compared to the center, because a piece or sketch spread is unlikely to keep the center of sight so as to keep the plant in the center... and its getting away day after day is at least suspicious.
I also think this has happened to me (but I don't put my hand on fire) since I started making the tables quoted to produce, not in the modeling phase.
advice?
where are the general plans?
Do you have any empty assemblies in other overalls?
solved!
the axieme is sufficiently heavy to push in program to make fast loading andnot the complete one. fast loading makes quite rough geometric approximations. Sometimes these are also visible as lines that do not hit anything, strange cones...these errors accumulate getting worse and getting away from the only modeling area. in this case errors are not visible. Therefore, opening after opening, the useful model is increasingly far away because the visible area is occupied by geometric errors.
resolution:
every now and then I'm going to have the full load of the axieme (with which geometric errors fade away), save, and everything goes back for a few days!
