view levels
  • Thread starter Thread starter ocraM999
ocraM999
how do you view a level that exists but does not appear in any section view or prospectus?
e.g. I see the liv -1, liv 0, liv 2, liv colpertura. . .
and liv 1???? Where is she?? ? ? ? ? ? ? ? ? ?
checking in individual views of prospectus or section or detail the liv 1 is not among the hidden elements.
in graphic visibility the levels have appeared in fact I see everything except the liv 1.
if in cutout view I remove the check and check also in hyperspace I do not find any residual level.
If I make a new section all the same.
Thank you
and how do you know that the level exists? Did you see him in any of the views?
Most likely the level does not exist. someone deleted it or renamed it.
just for scruple go on "view" -> "plant views" and look in the box, if there is something like "liv 1" then it is somewhere, if instead it is not there and you do not even have it in the list "floors" then it doesn't really exist
but if it is in the browser and open the view to it connected (click 2 times above) what do you see?
is it not that by chance the level that you cite is placed so high or so low that in the "normal" view of section and prospect are not seen? Did you zoom in?
the point is that I do not find it in any of the existing sectional or prospective views or create new ones. not even, as I said in the opening, zooming to the "hyperspace".
I did a test: if the extremities of the model (the white balls that appear by clicking on the level line) are dragged to join and the symbols have previously been hidden, the level line disappears in the views.
could this have happened during work(?) however there is a way to restore, review, see or find this cursed level that is surely somewhere?? ?
Mar
the only solution is that that level does not exist and you find it on the browser only because that is a duplicate view to which they gave the name level 1
you did not answer the previous question: what do you see when you opened that view?
... I see level 1 .... )
level and view are two different things. What do you see? a view (architectural plan) or a level (the symbol) in the view of section or prospectus?
Therefore, it is not a level, but a view. you can have a plant that matches the first level without having a level called "level 1". views and levels can have different names.
