view of red detail
  • Thread starter Thread starter Enrico Lugli
Enrico Lugli
Good morning.
I'll explain the problem I can't find a remedy.
using the command "new from" I made a copy of a set and its table, on the copy 3d I went to make changes and I replaced some pieces that compose it with others.
When I set the 3d of the axieme I go to open the table and I find some "views of detail" that are red (for accuracy is red the circle and the letter of detail ), as if it had lost the connection to the view on which they were made.
Is there a command or procedure to get everything back to normal without having to delete the details and do it again? ?
Thank you very much in advance
you exist in the properties of the view a voice that force the update or seems to me the synchronization of the design. try to find the function otherwise when I return I could find the documentation and help you. we also had the same problem and ds formed this solution that works well. absolutely not to erase them to give them back you would lose a lot of time.
it seems to me functions regarding updating and matching of the detail view with the model; However, to me remains the purely graphic problem of circumference and red call line (r19). Of course you can wander around, changing the color "hand", but remains a little bit of awe. Any ideas?
martial
in the context menu of the detail view you should find the command to update it so as to avoid "the red circle"
