view problem part in set
  • Thread starter Thread starter Byron
Byron
Hello, in a collection I would need to show a colored part and one in "removal hidden lines" mode but the result is that in enclosed photo, the cod that enters the "white" part appears whole instead of with the hidden area. What is the solution to this? does not exist a "order" of display or similar things?
thanks to those who will answer me!
design environment, part or together?
What is the purpose of this manoeuvre?
Hello Mass, thank you for your interest. They are in the environment of together, to pour then on board. I need it for the graphical style of technical documentation. in practice the part in "hidden line removal mode" comes from a previous assembly stage and must appear in this way.
have you thought to use to apply the envelope property to the parts and then get the image out of the design?
The envelope serves to represent secondary objects, so that they are by default excluded from the separate.
the part in envelope mode appears drawn while the other part keeps its contours and just set to display the hidden edges and you have the result, but without colors
I thought about it, but I can't handle it in this way for technical office rules, I can only use graphic options that are discriminated against by display states.
personally I'm pretty pessimistic that you can do.
if you find a solution let us know
