view quotations in interrupted section
  • Thread starter Thread starter solids
solids
I continue to have "rogne" with quotas when I have an interrupted view.. .
In the last case that prompted me to write this post I made a section view. this section view was too large and I therefore used the interruption of view. fact is that if I interrupt the view, even bodies that after the interruption continue to be completely visible in the view, are no longer selectable from the command quota. If I cancel the interruption, those same elements have no problem being quoted.
I said little wrong to myself... at the maximum quoto first everything and then I create the interruption....but even if I do not interrupt any quota, some of them become unscrupulous and others to move in abnormal positions... and to conclude, if I cancel the interruption to make "reprise" the constraints to the quotas, they move very far from the drawing (and in addition not the ctrl+z will relay them...)...
Why? ! ?
ps: I also made a video.
here the unselectable elements of a sectioned view http://www.yourfilelink.com/get.php?fid=1472911here the odds that go walking.. . . http://www.yourfilelink.com/get.php?fid=1472912
video can also be attached via advanced mode
was just to use a faster system, among the available extensions I did not see video formats and I avoid creating compressed files.. .
in any case, if provided for in the regulation, forgive my lack.
[OT] How can I change a post I published? I can't find the "modification" voice. . .
you can edit a message only within 15 minutes (seems) since you published it
if you upload the two videos to youtube or vimeo?
Anyway, did you get to see them?
I have not found any anomaly like those described by you.
try contacting assistance
