view scale format
  • Thread starter Thread starter lupinIII
lupinIII
hello to all...I have a small problem with wf4 proe: when amounting a view in a drawing, its scale is displayed in decimal format. I would like to view it as a report, so I tried to set in the design option "view_scale_format" the value 'ratio_colon' but nothing changes. Can anyone help me?
Yes, you must also set view_scale_denominator to 10.
naturalmete then you have to save everything
I would also have a question about the subject and this is:
setting the above, instead of the bar (e.g. scale 1/1), can't you have the two dots (e.g. scale 1:1)?
excuse the intervention on this discussion (... I have not found any more on the subject of my interest) ...
going to insert for example a scale 1/4 (or 0.25) in the table is indicated 3:10 and not 1:4 from which string of the dtl depends all this?
Excuse me, I don't understand the problem.
the only thing that comes to mind is this depends if you have selected default scale sheet or custom scale:
01.webp02.webpBut it seems too trivial. Can you post an image?
He does it to me for all the stairs that if they were translated into decimal they would have 2 or more digits after the comma.
I have wf4. Try all the options. I never noticed because I never use the scale 1/4
(use 1:1 1:2.5 1:5 etc.etc)
as not said:
put view denominator scales on 2 in the config.dtl
Yes! problem solved, thank you 1000!
but I did not understand if in time I never used stairs that gave me that problem because the value of view stairs calledr was always 10.. .
:confused:
anyway thanks again painaz
