view the preview of the rotation angle
reggio
hello to all, I apologize for the unlighting title, but I did not know how best to expose ...
It is this, I have "the impression" of having seen so many years ago, that autocad, moving the mouse, allowed to see the preview of the angle of rotation, the command seems to me was precisely the wheel command that once selected the object and given the point of rotation, showed, moment after moment, the value of the angle...
Maybe it was an application, but it came back to my mind now that I'm stretching out to rotate several pieces and I was wondering if it's an option that I can activate on my acad2011...
What do you say? ever seen before? :redface:
f12 prizes and activates dynamic input
hello tristan, thank you, but it's not f12, I try to explain better:
with f12 only the "specify rotation angle - 346°" box appears to me, but the value 346° does not dynamically change the mouse position,
what I remember instead changes dynamically and would make me understand that (for example) to about 187° my piece will touch another piece, allowing me to know at the flight which angle then insert and confirm really ...f12.webpfor example, see the x,y,z coordinates that are indicated below left?
if I move the mouse also coordinates vary dynamically and show the new location ...
Here, what I remember, did the same thing but with the corner...coordinate.webpI repeat, maybe it was a dedicated application or maybe I remember badly :confused:
Can't you think of anything now?
proof così:[Input dinamico ON] select the rectangle in order to see the grips; click on what you want to become rotation pin (start the iron command); press the space bar twice (cycle on wheel command).
now the corners are shown in real time. enjoy!
great!!! :
It works!!!! now the share of the corner moves!!!! :
